Changing brake master cylinder
I need to change the brake master cylinder in the very near future. Has anyone done it on their car before. Is it an easy job and how long should it take me. Anyone got any web pages to help?
Thanks in advance.
Paul.
hi bud i did mine today it's not to bad you just undo the 2 brake pipes i recommend a brake pipe union spanner for that then there are 2 12mm bolts on the servo holding it on i had to unbolt the cruise controll solenoid to get a little more space, i fitted new pistons seals in mine a lot cheaper than a new cylinder, took me about 1.5 hrs then had to bleed the brakes through to remove air from the system hth kev
Lovely, thanks for that. Going to do mine today.
