When changing the clutch????
What else should i do or replace?????
(Apart from the addition of lightweight flywheel!!!)
clutch release bearing and spigot, well worth doing the rear main seal and check the condition of the water hoses that go to the nearside turbo as when the gearbox is out it takes 2 secs to change them
Ryan
Also a good time to change the knock sensor and harness (see courtestpart.com) if you've been getting the error code 34.
Regards
Simon.
