STRUT BAR 300zx
Hi All !
I just want to know if the 300zx NA FRONT & REAR STRUT BAR fits on all 300zx Model (NA, TT 2seats, TT2+2 seats) , or just on the NA model...
thank's :)
Hi All !
thank's :)
Yes it should - depending on the model and make of the strut bar. Bear in mind that certain strut bars (for example, the Stillen rear strut bar) will only fit if you've got aftermarket suspension fitted - the bolt pattern is different.
Cheers,
Dan
I dont understand this about certain rear strut bars only fitting with aftermarket suspension do you mean coilovers .I have teinflex on mine and the stud pattern is the same as the standard stuts if it was diffrent they would not fit .Can someone explain please thanks taff.
Sure, there are certain aftermarket suspension kits available (I don't know which ones though) which have a different stud pattern - possibly four studs in place of three or even two. Can't be more specific than that. But if your Teins are the same stud pattern then you shouldn't have a problem with most strut braces.
By the way, how do you like the Tein Flex system? I've been toying with the idea of putting them on my car at some point but have heard feedback varying from "great" to "pants" so would like to know how you like them. Did you get them set up professionally?
Cheers!
Dan
I have a 300zx TT 2+2 seat EUROPEAN MODEL... with Stock suspension...
and would buy a STRUT BAR .... but, it's for NON TURBO MODEL... (very beautiful strut bar with Z :p)
see here => http://www.procarparts.com/store-detail.asp?sku=NS9030%2D6943SBX&dbname=onlinestoreDB
can i fit these BAR on my Z or not?? :roll:
I agree with you mate very nice looking strut bars, I wonder if you can just buy the front one as the rear strut bars are a pain in the a55 to fit, and you hve to cut the rear trim. But in answer to your question yes I would have thoght they would fit specialy as in the description they say they will.
Danny @ Dta (above ^^) sells front and rear strut bars.
By looking at the support towers on the picture provided I would say YES it will fit a Euro ZX with stock suspension setup.
Dan
Dan
:hyper: :hyper: :hyper: :hyper:
If the support towers not fitting on my Z , i'll modify them :D
but i don't know if the height & length is the same for the STRUT BAR on 300zx NA and TT :( :headvswal
NA & TT are indentical.
I can confirm that Stillen rear struts fit a zed with KYB suspension fitted...
And that I have a very similer front strut brace fitted as in speedydemons post and had to remove my cruise control to fit...(although it may be possible to modify/adapt the c.c unit to mount it again but didnt try as who the feck uses c.c on a Zeeee :x:
Also..if using a std bonnet you will need to modify/adjust(with a hammer or jigsaw :x: ) the bonnet to make it clear the strut brace :smash:
As for the resulting performance of both :bow:
If you buy from here ask for edwin and tell im adrian from england sent you and hopefully get a bit of discount also he is very good with sending out unmarked if ya know what i mean if ya dont P.M. me :D
FAO danny dta tein type flex where fitted on my z when i came over from japan they look new.so i dont know about set up .But i have lowered it a bit on the back since .Since i have never driven a 300zx with standard or lowered springs and uprated shock set up i dont know the diffrence.I also softend them up as when it was imported they were on full hard which belive me is hard .But on middle setting there ok for road use .Also are you likley to order anymore carbing strut bars from japan in the furture thanks taff.
Thanks for the feedback taff.
Yes, I will try to import more Carbing front strut bars in the future but as you know they are notoriously difficult to get hold of. If they haven't already sold out their 2006 production run for the 300ZX then I will do my best to get some more.
Rgds,
Dan
