Profec B II settings
Ive set my profec B for PSi and trying to get a decent base level of boost (say cirrca 10psi) in Lo, and then 14/15psi in hi.
Ive searched and found several lists of setting but not sure if they actually for the psi or kpa settings on the controller. Also the instructions hint that the unit gives real time boost so although my after market boost guage is fairly crude (last owner got one that reads in bar not very acuratly..) can i just get a passenger to read the boost levels out as i drive and then use the peak recall to avoid dangerous boost.?
Currently set as:
Loset: 16% Gain:18% Setgain: :48 Warning : 110 drop 20%
Hiset: 33% Gain:21% setgain: :85 Warning: 155 drop 20%
cheers all
i had those settings mate and was getting quite a big boost spike, mine is in psi but i have my hiset at about 37 with my gain only at 7! still get a bit of a spike but cant seem to get rid of it! i get about 14.5-15 psi. the rest of my settings are the same as yours....
let me know how you get on..... cause if you don't get a spike then my solenoid may be faulty!
no problems, il give the car a run out and see how i get on, just wanted to make sure they were sensible settings for psi and not KPA...
