Do both hicas and non hicas need 4 wheel alignment?
does a non hicas n/a need 4 wheel alignment? or just the 2 front wheels?
went to kwik fit garage this morning to get a front wheel alignment and he said ' nope cant do that here as you have a 300zx and they all have hicas..you need a computerised 4 wheel alignment which will cost up to 100 big ones' i said oh ok then knowing my car has no hicas ( 90 NA)and didnt want him messing with it ..i went home and called a few tyre places and they said the cost is expensive coz they have to adjust camber and caster...i have read on here that these are non adjustable..are the ****s taking me for a ride or what? :confused:
all I want is a basic wheel alignment so that my steering wheel is straight and my wheels are straight..is this too much to ask from a tyre shop? :headvswal
anyone had any similar probs? any recomendations?
Errr-think they tell you plenty crap bud!-Hicas or not, the alignment should be done!-Rear toe and camber is adjustable on Hicas,front toe only unless fitted with adjustable aftermarket arms.
You need to go to a place that does this only (if there's one near you?) as you get a better service from someone who does it day in-day out IMO!
Find a good bodyshop that fixes well smashed cars .. they'll do a 4 wheel geometry check for you.
the front track check ca nbe done by anyone . so persist wit hyour local garages . hicas or not
Yep but we all know they'll Fook' It up!!! .. M5 was .6 of a mm out and felt like a shopping trolly!!! .. Get it done properly please !!!!
The checking can be done by any old tyre shop to see if it may be out. However to have the allignment altered/corrected you'd best take it to a 4 wheel allignment specialist.
There are a few around and the cost is not so bad - around £60 for 4 wheel adjustments, £30-ish just for fronts. Look in Yellow Pages - often specialist alloy wheel suppliers/fitters will have the facility.
Richard :smw:
went to kwik fit garage .................?
Where in London are you mate?
When I lived in the East End I used to go to Elite over in Rainham, just on the A13 near the Ford factory.
Richard :smw:
Richard :smw:
hey Richard,,Im in East Finchley..found a guy who said he can do it for between 47 and 80 big ones max for the 4 wheel..he has a tyre shop in my local high road that I never even knew was there..He has the proper gear..I think this sounds like the go..what do you guys think?
