Rev Limiter?
Can anyone tell me what the rev limit is on a unchipped TT?
I get a missfire at 4-5000 rpm.
Its a jap spec but with a uk clock.And i was wondering if this has anything to do with it.
Steve
Yeh i thought it would be around there.
So what the hell could be causing a missfire that high up the range?
I really would considder changin the spark plugs dude as they might be fowled up or the sparking gap is set a little too big.... Worse case check all the coils and make sure you have no breaks in the wires and the connectors arn't corroded... Hope this helps!!! ;)
Deffo clean the coilpack connectors.Cant do any harm giving the a good clean up.i had a missfire on one cylinder,cleaned the first connector i came across-problem solved-proceeded to clean the rest as a preventitive measure.
If the car has been derestricted by use of the usual component attached to the clocks, I would check this. Some of these delimiters seem to fail quite readily with some unusual symptons. If in doubt remove it to see if it improves.
Thanks guys i think i Know the problem now.
My race logic TC digi adjuster was set ti 4200 :headvswal :headvswal
I was so busy trying to sort out my low range missfire(dodgy ecu plug) i didnt think about my TC until i went to bed.
Thanks again
