Had a problem with a flat battery the other day, jumped it and then got Hicas & ABS lights flashing. So decided to charge battery up fully and after charging, it was reading a little over 12 volts, put in the Z and then car started fine, did a test once engine started and volts where showing at 14.42, but after revving the car it showed no volt increase and after a couple of minutes running, the volts were slowly decreasing.
Hi there,
Is the Alternator faulty which it sounds like?
