above the stereo and under the vents. Everbody says that these break. I've had a look at mine as it's stuck on with black gobbo but it doesn't look broken. Should it fit into metal clips on the dash as in mine there are just rectangular holes and nothing to hold it in.
ย
ย
CheerZ
Paul
...it should have metal clips attached to the back of the strip and these clips fit into the rectangular holes.
ย
Double sided carpet tape works better.
ย
Good luck
ย
Jack
Black stichies on mine, been on and of a few times and still fine.
Mines held on with those metal clips.
ย
speedemon, are the metal clips in the dash trim or on the plastic strip
ย
do you have a picture at all mate
ย
ย
CheerZ
Paul
the metal clips are on the back of the plastic strip. Mine was loose as hell so i stuck it on with prit pads. Only problem now is that its stuck on so well I think i'll have to break it to get it off again.
I got a new strip from courtesy Nissan. (cheers Ya5een)
ย
The new clips hold it very tightly. Cost about ยฃ10 all in if i remember rightly.
ย
ย
ย
CheerZ
Paul
The clips clip on to those plastic lugs on the back of the strip I will post a pic for you in a while.
