Spark plugs!!!!!!!!!!!!
What do i go for?
Hotter, colder, copper, iridium or influx capacitors FFS :rofl: . I have read many threads and the time has come to start winter maint, with the plugs being the first on the list. Im running the Zed on a boost controler, chip and filter. Thats the only engine mods so far. So whats the latest then LOL. Look forward to seeing what everyone is running on ;)
[sIGPIC][/sIGPIC]
if running higher boost you need colder plug NGK PRB6B-11B's are plats and are recomended by most peeps on here thats wot i use, i was using hks iridiums before they also were good plugs but cost £15 per plug.
Go for hks plugs mate you can get these from sumo power tell them your engine spec and they should tell you the plug grade.
Cheers lads. Any more??
[sIGPIC][/sIGPIC]
I'd go for HKS S40i irridium. its a little cooler than standard as your running extra boost and more fuel. + They will hand the punishment and deliver a good spark for 60K and beyound.
Am not up on the HKS ones mate, however as your running Nitrous then certainly you need colder ones around 7 which the S45i might equate too, i dunno, soz but certainly any other Zeds with small mods or even quite a few, 6 heat range is certainly best.
Oh and if you search, platniums are reccomended over iridiums by most ;)
theres some pics somewhere around showing the differences.
smithy
