Brake cylinder stopper
Yup, they do work by stopping the firewall flexing as you brake and Danny DTA on here sells them.
and probably cheaper too £12.99 for P&P!!!
Vijay
Yeah a good mod, you can feel the positive difference in the pedal, had one on my 300 and now have one on my 200 :cool:
These really do make a difference to the brake pedal "feel", ie it firms up the pedal due to decreased flex in the firewall but it does not increase your braking performance (ie shorter stopping distance).
The ones we do are a straight bolt on item and comes with full fitting instructions and fixing bolts/washers. It is also adjustable so that if things do move around you can still adjust the brace to provide optimum performance.
Our item is priced at £25 inclusive of postage.
Dan
PS - I've just had a quick look at the ebay item and on first appearance it seems (a) a bit flimsy and (b) it has two parts which means there is an increased likelyhood of flex. I'm sure it's a well researched item and the above is just IMHO.
  • 3 years later...
Dan
digging up an old post but fitted one today and you can tell the difference straight away even on soft braking a good improvement to firm things up cheers danny
