Hi Guyz
Back end of my Z has been wobbling around for some time now and there is a little play in the back wheels (was mentioned at last MOT). So Ive decided that i am going to do some work to stiffen her up abit. Here's what I have got planned so far:
* Remove HICAS (because I want to, end of story :nelson: )
* Replace all shocks & springs (KYB's uprated non-adj & Eibach Springs)
What else could be causing the wobble that i can replace bearing in mind everything is stock at the mo?
Check the upper link suspension and subframe bushes too
Ok cheers. I will probably replace them anyway. Is it worth going for poly bushes after reading the warnings on here?
Also would this fix the play in the rear wheels? I can literally grab the wheel and rock it when its jacked up.
yep, worn ball joints on the rack end
ok so i will need new ball joints/hicas arms
Hicas arms caused the same problems with mine. Even if you eliminate the hicas system you still need to get new Hicas arms or you will have the same problem.
ok nice one..
Where did you get yours from?
ok nice one..
Got mine from the below:
Hello and welcome to RiceRocketUk. I have been in the Motor Trade for 25 years supplying parts for most types of vehicle on the road to the trade & public. I have for the last year specialised in the dismantling and supply of Quality used parts for the 300ZX Z32 and Mitsubishi FTO, I am located in the South East just off Junction 9 of the M25 at Leatherhead,Surrey and parts may be delivered or collected. Should you require any parts please feel free to contact me at any time by the following methods:
01372 813861 Work
07831 147200 Mob
mjd128@hotmail.com
By PM on the Forum
Payment methods accepted: Cheque, Cash, Paypal or Bank Transfer.
Many thanks for your interest.
Thanks matt.
Anyone else think of anything else i should be looking at??
