how much popping from exhuasts is too much?
- Tap Permissions โ Notifications.
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
- Open Settings App โ Notifications.
Safari (macOS)
- Go to Safari โ Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Go to Settings โ Site permissions.
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
My zed pops a lot from the exhausts when you accellerate and come off throttle, obviously more so the harder you accellerate / the further up the rev range you go. For example, if you accellerate briskly in third gear up to around 5,000rpm and come off throttle, as the revs come down you generally get 4 or 5 pops from the exhausts. Id say its more prominent now the weather is colder. Personally I was quite happy with it as I was (still am I think) of the opinion that this was fairly normal for a car of this nature and with the spec that it has. But today I took my brother, a NA owner for three years, out for a drive today and he thinks that it shouldnt be doing it as much as it is and that in the long term it may lead to detonation. He thinks that the fueling is wrong. The car has twin blitz filters, de cat, powerflow exhausts, and has a manual under bonnet boost adjuster valve. I was told by previous owner charlie (300horses) that boost was set at 0.8 bar and amoungst the service records a boost upgrade is mentioned but I do not have a aftermarket boost guage installed so cant be sure exactly what boost is being run. All I can say is when you give it full throttlle the factory boost guage takes the whole of the rev range to reach 0.7 bar so id say that its running pretty standard boost.
