Heater Bleeding
is there a set way of bleeding the heater on the 300, cant make the heater vary warm at all, cheers woody
remove bleed screw from left side of radiator,once warm put heating to max,the top up rad from rad cap,and squezzed the back heater martrix hoses,they tend to get an airlock between the engine and the heater matrix so a good squeeze at the back of the engine,normally works keep topping up until no bubbles are present and full heat is coming out
or.... if your heaters fooked like mine is get greg to put a new one in there..
im comin to see ryan and you shortly greg me old son!!!
Muhahahahahahahaha!!
was that scary enough?? :tongue:
thanks for that, just fitted new mattrix so will try that tomorrow, when i am allowed back in the garage, but must keep the side up for the mo :duffer: :duffer: cheers woody
also try parking the car so that the front is higher than the back, that way it saves the air getting locked in the back of the engine.
