My Expansion Tank was full to the top??
I took my expansion tank off today to see why I was losing water from my radiator so much, It was full to the top with water way past the min and max marks on it, I think the main reason for this is my radiator cap is the original 92 one, which seems a right pain to take off, so I presume its not releasing the pressure properly. Would this cause the expansion tank to over fill and release water?? I have sorted a cap now. Thanks in advance. ;)
yes a poor sealing rad cap can cause this or if someone has deliberatly topped it up,remove the excess water with sucker or just drain the expansion bottle so the correct amount is in there
Greg please can you tell me what the black tank behind the expansion tank is?? Is it the A/C fluid??
The carbon canister is in front of the expansion tank (and it's black :D ) Not sure what's behind it tho... :confused:
Steve :)
'93 UK TT Manual
Steve :)
:confused: :confused: :confused: My expansion tank is like a white plastic tank with a yellow cap and behind it is a black cylinder shaped tank with a lot of small hoses going into it?? And behind that is the back of the fog lights.1992 Jap import 2+2
:confused: :confused: :confused: My expansion tank is like a white plastic tank with a yellow cap and behind it is a black cylinder shaped tank with a lot of small hoses going into it?? 1992 Jap import 2+2
LOL - no I meant that the CC is black! I'll dig up a picture in a mo...
*EDIT* FFS - the site hosting it is down - but it typically has 4 hoses connecting into the top of the CC ;)
'93 UK TT Manual
WTF is the Carbon Canister for?? :x:
Fumes from the gas tank are sealed from the atmosphere by the gas cap at the fuel filler, and stored in a carbon canister (CC) for reburning when the engine is running. The CC, gas cap, lines and controls are sometimes collectively referred to as the EVAP (evaporative) system. A car’s EVAP system is passive. The gas fumes are trapped in the carbon canister while the car is at rest, then purged back into the intake system using vacuum pressure when the car is running.
Bin it ;)
'93 UK TT Manual
