December 19, 200520 yr basically my det sensor is on the blink-tym to sort it out! what do you guyz think about bypassing it-whats the pros and cons???? :confused: :confused:
December 19, 200520 yr IMO Bypass it, and if you ever have the engine out change it then. Pro's - It costs about 5p and takes 5mins, and returns car to correct peformance (have seen losses of 100bhp with the car in safety mode on a dyno) Cons - ECU can no longer detect det. However you have to bear in mind that it only works below 3000rpm and after that the engine is too noisy for it to hear dett. If your not running stupid boost, and the car is running right, and you use high octane fuel you should'nt ever get det anyway..and if you did, you should be able to hear it.
:confused:
:confused:
