In memory of Mandy
clutch vacume system
i have a suspected clutch vacume leak as my engine is stalling upon pressing the clutch down arriving at roundabouts etc.. question is ive checked out the diagram on the online manual, and then looked in the engine bay and cannot see the vacume tank and hoses coming from clutch master cylinder. all i can see is the master cylinder?
where is it all hidden? :confused:
thanks all..
far left hand side bud, to the left of the balance bar and back a bit. You will see a l shape non return / check valve and pipes coming ut of both ends. The clutch booster is right behind the clutch pedal which you can see if you get a torch out or get under the car.
The booster (vacuume servo unit) is inside the car, up under the dash by the clutch peddal.
