AFM Help Please.
HI All.
Having found that a running problem was being caused by the afm not working
for more than ten minutes is there any thing I can do to repair it or does anyone have a second hand one for sale at a fair price.
Any help would be much appreciated.
I expect you've already been told but have you tried disconnecting it to make sure it is that? It'll run but be restricted to 2k revs. Mine went the other day and Ryan at Zedtech sold me a second hand one. I've never heard of anyone fixing them? They work by the air flowing over a thin wire that gets burned when the rain going over it. Or something like that at any rate!!
Thanks for the reply Royal ,it defo is the afm I,ve cleaned the connectors even took the metal bits out and soldered them to the wires put the connector back together but still it only works for ten minutes then only gives 0.08v unless I give it a light tap then it will work for another ten and so on ,
How much can I expect to pay for a second hand one?
I had exactly the same problem.
Was to be the MAF in the end ;)
Many thanks guys ,I,m of to play hunt the maf.
A bit like hunt the muff but not so much fun.
