Hi, now ive got the looks sorted, im wantin to get a few more horses under the bonnet, ive got already exhaust,filter, dump valves and iridium plugs, ive a budget of about £600 for now.
im wanting to up the boost but what do you guys sugest and what bhp should expect to be getting.
sugestions much apreciated
Cheers Si
Chip and Boost controller!! Simple ;)
If its set up right, you 'should' see 300ish RWHP
thats what i thought.
which boost controler do you recommend been lookin at the apexi ones
Si,
As Rich said a chip and a boost controller will give you a mega power hike. I can supply you a GReddy profec B and a chip for under £300, leaving you another £300 to do some other bits to free up a lot more BHP, give us a shout and i'll sort you out :)
you will need a uprated clutch, I take it you have a manual. as a stock one won't last long
Si,
I used to have the GReddy Profec B spec 2 and its a great controller, but for me the GReddy Profec E01 is the danglies.
Rich
It rocks, dead easy to use, once you understand the terms... ;)
It also comes in Limited Edition black now! :D
Si,
cheers mate will do might be after chrimbo though.
what bhp would i get with that
when i bought the car about three year ago(im the first british owner) it had a exedy nismo clutch and flywheel fitted but was slipping virtualy as soon as i bought it so had it replaced but having just bought the car couldnt afford to replace with a performance clutch so i just fitted a standard one.
do you reckon the car could have more engine mods what with it having a pretty good clutch fitted.
although the car seems to be drivin ok with the standard clutch i only use the car march till october and not every day...
....this is probably an imposible question to answer to answer.
I eat clutches, but with a standard one it will start to slip in the higher gears, my car has/had roughly the spec your going for. 364bhp and 350 torque and the stock clutch only lasted a couple of months.IMO a stock clutch is good for 320ish and your going to be over that, so it will be a case of when not if . but could be wrong
just fitted boost controller and de-cats and its a different car! loads more power and the turbos spool up so much quicker! got my de-cats for £130 and the boost controler from chris (cheers mate :D ) profec b II, its ace and fits very nicely where the standard clock goes
