You're all a bunch of bloody ..... oops sorry wrong letter !
Anyway, I seem to spend a considerable amount of time searching around the various excellent technical resources on the Internet, but I can never remember where I last saw what I needed and the articles are arranged differently on each site. Therefore, I felt there was an opportunity to help out all the frustrated searchers. So having a copy of MS FrontPage (which I now hate) I have created a directory of all the tech documents that I have found so far (this afternoon).
Take a look :- http://www.300zx.org.uk
Comments, constructive criticism, additional links or suggestions are all welcome.
PS I Don't want to be a web designer - it's boring !
Andy
At first glance I cant say that there is anything wrong with it. Clear, user freindly and easy on the eyes.
Good job mate.
However, I would say, try and keep it in alphabetical order but if I'm not mistaken, it uses the Haynes manual order of reference.
No qualms here!!!
Looks very nice and easy to navigate bud.
You're better than me in that you produce something worthwhile while you're loafing! ROFL biggrin.gif
Cheers guys, I know there's bits missing and bits that don't work but give me time and I'll suss out what to do. Anyone know how the counters work ? Maybe it's just because BT's server doesn't understand all the FrontPage server extenstions ...
Why, when I click on Diagnostics, does it goto the BT Open World home page?
Because I forgot to upload that page! Will work now though. Keep 'em comming ...
In the Maintenance section, half the options are in a smaller or different font.
Your
Maintenance Intervals link
Opens the page in the same window. The others open up in a new window.
You want me to keep looking?
There is no search button on the homepage, but there is on all the others.
you want more?
I've fixed most of the maintenance stuff already but the font thing defeats me completely. It SAYS it's the same but it looks different. It is Micro$haft after all ...
Different Font size on Engine Contol Page
Fuel Filter Replacement opnes in current window not a new window like the rest
Engine Lub page,
How to totally Replace the coolant, link is to a TT.net post. If you are not registered it wont show
Brake system Page
"X-Drilled Rotors Install" font size problem
Electrical System Page
Font problem with
"Fog Lamp Bulb Replacement"
"Fog Lamp to Driving Lamp Conversion"
Glare Guard Removal
All below
Starter Relay Replacement
Centre Console Clock Repair
Jeff's Headlight Upgrade
Higher wattage globes for headlights
Higher wattage globes for fog lights
Higher wattage globes for reverse lights
How to clear the orange or red from your tail lights
placing an EPROM-socket in the stock ECU (Also Capital P needed for Placing)
Moving the PTU to prevent failure
Repairing a failed series 1 (pre 93) PTU
How to modify cruise control to allow speeds over 105kph: 89 - 91 Z's
How to modify cruise control to allow speeds over 105kph: 92 and onwards Z' s
Help! My fuses are all labelled in Japanese. What are they in English?
How to replace the wiring loom with the engine in place
Making the aerial go down when using a turbo timer
Modifying fuel injector and other electrical connectors for easier access and reliability
How to disable the 105km/h speed alarm chime
Open in the same window. When others open in a new window.
I presume that all the stuff you wrote opens in the same window and others open in a new window. I can understand this but it may become confusing when surfing through them and you end up having 10 windows open.
Other than that, fantistic work. Well done.
Stuart
Yep, I've tried to post TT.net threads and coz you need a login it doesn't play ball! Bummer!
Still this is just nit pickin' but has to be done...good job though Andy regardless mate. wink.gif
When are we up for a beer bud???
Yep! Andy that look s good to me wink.gif,fair play to you mate nice one biggrin.gif.
Andy,
I've had that font problem in other packages. I've managed to sort it sometimes but highlighting all the text I want the same, then changing it to something completely different and then changing it back.
No idea why it works but it often does.
Nice work on the Frontpage. I use Adobe Pagemill which does similar stuff if you like the idea of what it does but just not the specific package.
D
Thanks for the testing and comments chaps, I'll do a bit more tidying up.
Tim, I can usually force down a beer most evenings but I know you're usually at work. I haven't been over to Stevenage much recently, but we could do another Friday/weekend thing and get some of your stuff fitted.
Started filling in a bit more info and tiding stuff up a bit. Heading in the right direction I think. Good feedback from the Aus forum.
As ever suggestions welcome.
