tap tap tap
My engine sounds like there are a bunch of circus monkeys under my bonnet with little symbols! :rofl:
Sounds like noisy cams or something, can anything be done about it or am i stuck with it? it not loosing performance but sound a bit pants!
Could turn up the wireless :rofl:
Membership No 0780
INSURANCE GOOFA
Hi Brett
I had the same problem sticking cam followers.. Ryan from Ztech advised to try this.. I must admit I was a little sceptical but hey.. Warm your motor up then put about 500ml of automatic trans fluid in to your oil .. leave the car running for about 30mins don't drive it.. Drain oil replace filter and refill.. Car will still rattle for 50 -60 miles or so then it just sorts it's self out.. Or the followers are totaly worn and need replaced .. but thats a big expensive job..
Give it a go fixed mine
Hi Brett
Cheers bud, ill give it a go next time i do an oil change as iv just changed mine to fit my oil temp and pressure senders!
Still want to meet up sometime this month mate? im going down to SAS in dundee tonight to re-fill my Nos
Can never change ur oil too much bud! ;)
yea but iv only done about 10 miles since!! could start to get a bit expensive!
Hi Brett
Yep I'm hoping to get my car back after full respray by the end of next week then rebuild it and fit my new toys. But yer welcome to gimme a shout anytime your this side of the Tay
Craig
Hi Brett
Craig
Ok mate cheers, can you MP me your number again as iv lost it!!
Mine had a bit of a tick to it, so i switched from castrol rs10-60 to valvoline fully syn 5-50 and problem solved.
Try Amtech engine restore oil....get it on ebay
Before I rebuilt my engine it sounded like a fiesta but it would come and go as it pleased souded horrible thought it was the lifters but turned out to be the inlet cam pully had broke the internal spring that sorts the vvt
owch.. sounds expensive?
I got a secondhand one mate, problem solved
I got a secondhand one mate' date=' problem solved[/quote']
is that engine or part?! ill try the simple things first and pray that its a easy fix!
