Settle the dispute
ok, i have a completely standard Zed. As most of you probably know the auto is dead so i have no power at the minute however . . .
. . . Once i convert it to a manual i will then have a standard manual TT and i can settle the dispute as to what BHP they actually have.
Who would like to know? :D
Membership No 0780
INSURANCE GOOFA
  • Replies 48
  • Views 1.9k
it aint going to be slower but define normal auto manual tt n/a or variations so you cant say slower there all feckin fast
StellaZ, i dont think mark is going to get back to us so if he doesn't tonight ill have to take kirbz offer as need to sort asap now
Membership No 0780
INSURANCE GOOFA
So on a manual conversion it should be quicker than a standard manual :confused:[/QUO
probably not.
probably not.
would it be much slower?
Membership No 0780
INSURANCE GOOFA
it'll be loads slower if you've still got a code 34 :nelson:
I should have known that was coming, it'll either be replaced or by-passed
Membership No 0780
INSURANCE GOOFA
Either way a manual conversion will get your car back on the road and StellaZ's car is slow because it's a fridge on wheels. Now if it was blue.........................
Either way a manual conversion will get your car back on the road and StellaZ's car is fast because it's a rocket on wheels. Now if it was blue with two turbos it would still be slow as fook lol
he he :rofl:
cheeky monkey :smw:
Here are a few reasons for the differences of the auto-man questions:
Taken from the FAQ section of TT.NET...
Does my automatic Twin Turbo really have 20 horsepower less at the flywheel?
Yes. I couldn't believe it, based on the performance of the two cars, so I did some research.
I found two quotes from books written about the Z:
"The four speed automatic was also available in the Turbo but in deference to the auto boxes longevity, the engines power output was cut back to 280bhp by different camshafts and fuel injection maps. Torque remained the same." From: Illustrated DATSUN/DATSUN Sports Car Buyers Guide by John Matras.
and:
"For various reasons the 300zx Turbo in some versions is rated at 280bhp. This applies to the Japanese market, where the manufacturers have an agreement to limit outputs to 280, to automatic trans models in the US, which have different camshaft profiles and fuel injection settings, and to the European market 2+2 because of its setting for lower-octane unleaded fuel." From Nissan 300ZX - The Enthusiasts Companion by Ray Hutton
I asked people I know at Nissan USA and Nissan Japan to confirm the horsepower rating of TT's with automatic transmissions.
The response I got from a contact at Nissan USA was:
"Aside from minor changes in the ECU, the cam profiles & turbos are also different between the M/T & A/T models. The A/T has 240 degree intake cams & 248 degree exhaust cams (the M/T has 248 degree cams for both intake & exhaust). Also, the A/T uses smaller turbos for more responsive low speed acceleration (the A/R ratio is 0.63 for the M/T & only 0.54 for the A/T). Even with 20HP less, the A/T turbo is capable of beating the M/T turbo to 100MPH."
I checked the fiche in the 'DOCS' section:
There were always different ECU's for manual and auto cars.
The camshafts were always different on the autos until the 1996 model year, and the part numbers changed three times. In 1996, Nissan discontinued the variable valve timing system, and rated the TT engine at 280 HP.
The exhaust manifolds (from the cylinders to the turbos) are the same for all years.
The turbos were always different (see Nissan USA comment above). They went through two part number changes on the right hand one, and three on the left hand one.
The exhaust housings (which attach the pre-cats to the turbos) were different for manuals and autos only from 9/93 to 9/94.
The manual and auto had different pre-cats, and the part numbers changed three times from 1989 through 1995. Both cars used the same pre-cat for the 1996 model year.
The H-pipe was the same for both manual and auto cars throughout production.
The main mufflers were different throughout production - even for the 1996 model year.
The auto has a different radiator, to accommodate the need to cool the transmission fluid. There were no part number changes throughout production.
From all of the differences in components, it's pretty clear that Nissan did some serious engineering to get the two cars to perform much the same way even though the auto model is down 20 HP.
you should be able to work it out from that bird buddy ;)
[sIGPIC][/sIGPIC]
and:
you should be able to work it out from that buddy
FFS mate, that was fantastic, bet ya fingers hurt now tho
he he :rofl:
cheeky monkey :smw:
PMSL
BTW it's still a fridge on wheels :rofl: :rofl:
PMSL
a fridge wit a dint in the side of
either way fridges are cool lol
well inside anyway ha ha
But you still got auto tubs! :D
Know all....... :D
and auto camshaft profiles
Statto.... ;)
not sure there is any dipute over power
Newbee.......... :nelson:
there is some difference apperantly, dont know what exactly
Have another Stella won't dive you the answer but what the hell.... :duffer:
less power will be lost with the manual transmission, so it should be quicker
At last a post that adds up....... :bow:
Or BLACK
and:
Stato Mac 2
If you change to a M/T then sort the e.c.u. you should find the 0-60 times will be quicker because the spool up is faster it will be easier to get power faster, all you will lose in theory is a bit of top end speed.
Stato mac 3.
Sorry all Just had to do it.......you lot are great but just had to take the pee...
Only jokin though... :bow: :bow: :bow: to all the zed nuts & (bolts) on here.
