Traction Control question?
I appologise if this is getting boring. BUT! to save a lengthy search........
How much does it cost (estimation) to fit TC and how difficult is it please?
PM Cybernet. He is RLTC reseller and installer on forum (or is going to be)
It's pretty straightforward to do if you can solder etc. I reckon it would take around 3-4 hours to do properly (and neatly).
I have no problem with a soldering iron. I work with electrics (not electronics tho) in work. But yes I am quite proficient with a soldering Iron.
Thanks i will contact him........
Ive just fnished fitting one and if this bloody rain ever stops ill fit the digital adjuster.
But apart from thjat they are pretty straight forward.Just take your time.
Good Luck'
It's not too tricky if you've got some soldering experience Vini - you've just got to take your time and tread carefully ;)
Feel free to contact me if you need any more info or if you've got any specific questions..
Steve :)
'93 UK TT Manual
Fitting will be approx £150 depending on distance to travel and options required. This will include full configuration of wheel sizes, slip control, minimum operating thresholds and launch control. You can view and change your settings using a laptop or the optional Digital Adjuster.
Steve :)
'93 UK TT Manual
