Ugly Aerial
Is there any replacements for the aerials that we have on our Zeds?? It looks crap when its up.
Is it possible to fir one that runs along the rear window or something?
There are 2 aerials on the Z, one is the electric one on the drivers side.
The other is built into the rear window right at the top, looks like part of the rear window demister but it isn't. You could try that and see how it performs. Probably not very well but worth a try ;)
I (and several other members) have wired in a separate aerial which runs along the windscreen and down one of the a-pillars (bought from Maplins.co.uk). Did this because my OEM aerial went kaput some time ago ... Reception isn't great but certainly better than with just the rear screen one. Alternatively, I've been researching those little "bee sting" aerials which are usually fitted to BMW's and Mercs. The one I'm looking at is mounted in the same place of the OEM aerial (you have to remove that first though) and it is also a GSM and DAB antenna so great for your phone and digital reception. Only downside is that like the OEM antenna it is vulnerable to being broken off by hoodlems ... Have installed one on an NSX recently and it's a vast improvement on all fronts!
Dan
