FAO Manwell owners!!
Fitted the new clutch pedal today and it sits about an inch higher than the brake pedal!!-I don't mean ''in/out'' fashion but like the pedal is too short-just wondered if this is normal??
TA! :D
mine is higher, will have a good look in the morning
you can adjust the height with the switches on the clutch pedal, but if your using a uprated clutch they recommend setting pedal higher and push rod adjusted to suit
Yep sounds about right to me (I did check :D )
Cluch pedal is slightly higher when depressed.
