annoing evil noise..!
hi peeps,
ever since i bough my Z as i drive along i can head a blipping noise very similar to the noise made when youleave the lights on after turning the ignition off..!
this happens any time, there is no warning light and it never ever goes away until switch the engine off...
FFS...! what is it.?? :headvswal :headvswal
is driving me mad :rant:
hi peeps,
is it when you get to a certain speed,if so you can remove the wire to the chime box,IIRC remove the hood that goes over the steering wheel 2 screws,look to the back and there is a little black box,pull the green wire out,insulate it,no more chime :D
thanks bud so what on earth is that chime?? now that you mention it is after certain speed that it comes on
Speed warning. Common in Japanese cars, possibly legal requirement? To warn them that they are exceeding the speed limit (about 65mph)
nasty piece of kit
hi peeps,
this happens any time, there is no warning light and it never ever goes away until switch the engine off...FFS...! what is it.?? :headvswal :headvswal
Meaning you do 65mph all the way, untill you turn your engine off :confused:
nope...!
meaning that ill happily drive along hit 65 MPH engage annoying chime which will not got away until i turn the engine off..! regardless of what speed i do after i've hit 65MPH :headvswal
nope...!
Thats odd, before I had my delimiter, when my Z would chime above 65mph it would always stop as I went below 65mph??
Got one on mine but it only comes on when i hit 105mph and stops as soon as it drops below that speed
Lucky bugger
Yeah, mine does it but at 110mph and stops when i drop below that speed
...we'll all be out tonight driving at 111mph trying to get it to bing... Mine bings if I put the key in the ignition when I've deactivated the alarm but not started the car. It means I can't leave the keys in the ignition - bit of a pain when you are working on the car.
