Idle Problem
Hi All,
My car is idling at about 1300rpm, i've set the TPS, removed/cleaned/refited the idle valve, if i remove the yellow connector off the idle valve it has no effect, can i assume it is knackered.
Baz
have u reset the ecu bud as i believe the self learn adjusts the idle also ,This might get it to drop back down bud. Try unpluggin battery or using the conzuly to clear the self learn.
OK, thanks mate, i'll give it a go.
Baz
Think theres a plug you neeed to disconnect and re connenct with the engine running to complete the reset, im not sre which one it is but its near the tps somewhere,im sure some one techy will know which one.
