whats dripping?
After a run in the z tt I can here something dripping onto a hot surface under the bonnet, water or fuel :confused: I think fuel, sounds like its coming from around the engine oil dip stick area, but I cant see anything, it lasts for about 3 to 4 minutes after switch off, any ideas guys??
Also while im on here, any ideas how those rear spoilers come off?, are they stuck on??
sounds like condensation from your air-con - you had it running?
Yes maybe, left my daughter in the car while i went into a shop, she loves switches n buttons (bless her shes only 21) KIDS :headvswal
Thanks Jay, will give it a go A/C off.
If it's fuel you will smell it.
I had a tiny amount weeping from a filter that wasn't clipped on tight enough. Smelt it even with the bonnet closed.
Any noticeable water loss? If not, then probably condensation as mentioned before.
Rear spoiler - details to come from those that know, but yes, glued(sikoflex) and bolted to the bootlid
If its fuel dripping onto a hot surface I think I would not drive her till its sorted. :D
Thanks for the info guys, will have a look,, if it ever stops f*****g raining. :mad:
hmmmm mine is an n/a and i've been hearing that same noise, no water loss no weird smells must check for a/c off.
If I was a betting man I would say one of the water coolent pipes from the turbo has failed and needs replacing!!! Check yer water levels as you could end up loosing all the water in the system if it's not replaced in time like mine did once, then that's means new engine time as yer head will warp and crack!! :x:
99.99999999999999999999999999999% certain it's condensation from the a/c.
It drips on the exhaust at the back left hand side of the engine. My ZX does this - always has done. There is no loss of coolant or any other fluid and the a/c works perfectly.
In the summer, once the engine has cooled there is sometimes a small puddle of water under that spot. It's clear with no signs of antifreeze - nothing to worry about mate!
Richard :D
could be a air lock this causes a running water sound under acceleration from the back of the engine
Water level is fine :eek: thank f**k for that. But will keep an eye on those pipes in future. Will now try it with AC off. Thanks again guys :bow:
