boost jets
im looking to get some boost jets for my mate ,he wants about 13-14 psi any ideas where we can get some boost jets?
:dance:
The actual jets are called mig welding tips which you can obtain from any hardware shop or place where they sell welding equip, they only cost a few pence each. different size jets give different psi 1.2mm= 11/12psi 1.0mm=13/14 0.8mm=15/16 psi but you need a after market chip so you dont blow engine up
different size jets will also give different results on different cars, you really need a boost gauge installed first and then start out with the largest sized tip and work down until you reach your desired limit on the gauge, as stated you also need a chip first as you will need more fuel running more boost
There are also more than one size (externally) of the jets, the small ones may whizz straight up the pipe !!! Go for the larger ones which should be about 7mm think. Incidentally, I think Danny (DTA Motorsport) sells specialy made jets.
AndyP have you received the money for the chip? The boost jets are for the guy i've told you he bought the minec ecu ,he got a uk manual tt 2+2 and i've put a boost gauge for him but know he is looking to get the jets. thanks for the replys guys
:dance:
Not yet mate. Did you PM me your address yet ? I'll get it in the post ASAP.
