is this normal my car does 50 kms for 10 pounds of unleaded? everytime i start my car up i can smell some petrol.
go round all the fuel lines and give them a tighten mate.as for your fuel economy not sure as you have a tt but they are not cheap to run lol
if you work it out they do around 18mpg average - TT's that is
i know mine will do about 250 to a tank
I get about 240 to a tank, but I am very rarely below 10k rpm lol, ok not that high but you get the picture!
maybe your consumption is ok, but the fuel smell is something to worry about, could be a potentialy serious fire hazard. Check your lines are all done up tightly, and make sure theres no cracks in them, especially the ones which go down inbetween the plenum from the damper and pressure regulator
ok so mines normal which is good lol.
I think the amount of problems u have had mate , best would be to get ur car checked out i think, might be overfuelling or the usual fuel lines could be knackered ( cue danny/smithy with their fuel line kit)
Karl
Still dont think anyones beat my record.........
92 miles
£62 :bow:
92 miles
£62 :bow:
I have Chunkles,108 miles for £80 due to snapped vac line to fuel pressure reculater.
Reculater...Did that one come out of your bottom.....?.... :D
mines does 180 to a full tank. not bad where can i get it checked out and how much will it cost to check them out?
Doesn't sound too good :(
I average around 230-250 to a tank normal use and around 250-280 on a long run.
I have an almost stock Uk spec auto, plus I don't hang around either..... ;)
Richard :D
wil getting it chipped make a difference?
If you got a fuel leak then if you get that fixed and get it chipped it,ll probably work out the same! As for fuel consumption, if you are worried about that, cycle to work and let yer lady buggy on the crossbar except at weekends........thats what i do :D :D
As for the fuel consumption in mine i spend £2.00 warming it up £18.00 drivin it for about 20mins (sideways mostly with the dumpvalves scaring old grannies and my car beggin for mercy)
My philosophy Indian........ "God invented man, man invented machine, Turbopsychosis invented caus its fun makin babies and so he could try and destroy as much technology and machines as possible before cancer takes his life and he is buried in the ground!!!" So put simply FIX THE LEAK and enjoy the motor, fook what the consumption is the real problem is the tax on fuel !!! but thats another arguement for another day !! :rant: :rant:
check for dodgy egr valvle located at rear of engine, if the egr goes you get essesive fuel usage. mine went, it sounded like a exhaust blow at rear of engine when you rev up and let the revs die off
my exhasut is blowing mate
im not too bothered about the petrol usage as long as it stays in the late teens when im driving it normal im happy
