Just wanted to know if it's the same bleeding procedure for us/uk cars. I looked on tt.net and it says, left rear, right front, left front, right rear, abs actuator front and last actuator rear.
Also is it as simple as pressing the brake pedal with open bleed nipples to empty "all" the old brake fluid? and then do I have to flush it out with anything or is it just put new fluid in?
Vijay
Not too sure about the actuators but I usually go FL,RR,FR,RL.
If you have a spare 2 bodies it makes life a lot easier. You need one continously pouring fluid in to the resouviour, one on the pedal and one on the nipple(Ooooo!)
