low boost
ive checked my car and i am pretty sure it is stuck in the safety boost the needle does not go further then 7 psi, i have no idea what i am supposed to do. :headvswal
need some help and direction to sort it out!!!!!!!!!!!
:headvswal
-14 to -14
What fuel do you put in? Optimax or Normal Unleadded.
basically you need to do the following really. A: ECU Diagnostics Check to see of your got det sensor problems. B: Boost Leak Check, to make sure its not loosing the pressure. You can bypass the det sensor quite easily if thats the problem, downside is you car wont pick up on detting.
okay i need to start using optimax
my car is getting a diagnostig check this week
how do i do a boost leek check
and sorry but i dont understand anything about the det sensor, what do you mean it wont pick up detting????????????????????
Easiest way is to find somebody with a boost leak detector, you have to pump air into the system with the engine off and listen for leaks from all the hoses.
do you know where i can get that boost leak check done from
Possibly Mark (Topless) at Zen garage in london or Ryan (Baggins) at ZTech in Swindon. Best put a post request up and see if anybody near you come forward :)
thanks for all the help m8!!!!!!!!
