Maf
ok my car has gone bananas it started coughing and spluttering at the top end and on hard acceleration the other day after it had been raining, has gradually got worse and worse until this morning. It wouldnt pick up the revs then when it did the car was shuddering and popping and banging. When i revved hard it actually popped a couple of flames!! stalled a couple of times and reluctantly got going again..
dont dare try to drive it at the mo..
I think my maf has gone bang... is this right dyou think or is it just possessed??
cheers
Erm... don't want to worry you but it sounds a bit more serious to me matey- I've heard of similar symptoms which turned out to be the timing belt slipped or the tensioner broken. Deffo get it checked out properly before you drive it again :(
Mark
if you get time liam im sure ryan could swap a maf over for you and see what it comes up with,failing that do a consult or do an ECU diag see what it comes up with,my moneys on MAF as you say mate,doubt it would be anything to do with cambelt IMO
if they get wet they play up chronic
cheers
Liam
The usual fault on the maf is the car will not rev past 2500rpm.
If you can drive it under 2500 without the car jumping then its
the maf. :headvswal had this happen on mine :headvswal
Cheers matey
Yep, mine cuts out under hard acceleration when
it gets really wet since i fitted an apexi but its
fine in the dry. Must see if i can make a shield
of some sort
hmm kinda sounds likely then. Greg, problem is kangarooing it up to you!!! cant think of anything else it can be can you?? it only started when the weather got monsoon-like so am thinking that way.
Liam ifyou want to come over on Saturday morning early as i have a
busy day that day, we can whip mine off and try it on your car
it will atleast tel you if its maf
mate ta for the offer.. but cant do saturday!! typical innit.
tbh tho i am 99.9 % sure this is the prob..
bugger.. can you do me a favour and put a post up in jd-s z "maf for sale" post for me pls?? cant post in there aint got round to re-subscribing yet!!
can you cut and paste this "jd you got mail dude"
many thanx ;)
Done :)
LOL mark i like your avitar thread killer,hay it could well of been a cambelt issue at least its ruled out ;)
i normally kill threads with my big gob PMSL so were all at fault
liam looks like MAF then mate ;) before ruling out new maf mate place filter in airing cupboard overnight,leave battery off whilst doing so then refit on a dry day,might save you £200+ for a new one
thanks mark. Greg gotta be worth a try, shall i put the maf in to dry as well??
