window rattle - screw tight
I've got the window rattle problem and i've checked the bolts in the door pillar and they're tight. I've even had the doorcards off and checked every screw and nut i could find but everything's tight.
What else can it be.?
There seems to be play in the top guide, if i grip the top of the glass and move it back and forth sideways i can feel the play then. Is there some kind of washer that goes with the top guide bolt?
im sure jeffTT posted something about this, i'll try to find it???
thanks for the links guys but my rattle seems to be caused by the top part of the window being loose. The screw that holds the guide was tight but there was still play. I recon there's a washer needed. Let you know what i find.
