Quick question about wheel fitment
Will these fit my zed do you think? If they fit a Skyline will they fit a 300? So far the guy has asked if it is a twin turbo I have or not.
eBay wheels
I have Skyline wheels on mine and they fit fine. Only problem is that front and rear are the same width, ideally on a Z the rears should be wider.
Why can I never get this right. On my old zed I had kahn's with +35 offset. They say on the listing it has +35, so I thought it would be OK. On the listing it says fronts are 8.5, backs are 9.5 width. It lists the PCD as 114. I thought that was OK. The only thing I don't know is the centre bore. I never seems to be able to work this out.
What IS the correct offset? OR does it not matter as long as they look right?
Doesn't matter now - I've bought them :)
The guy checked it up and said it should fit. Hopefully they will be OK.....
Hope they go on ok mate, look like a nice set of rims! smithy has a mint link to work all that stuff out... try and get hold of him... he was loads of help when i had the same question
ill try and dig it out!
Stuning looking wheels Rich, will have to pop over when you got them on, when you going to AB bud and ill pop over if im off :D
z32 stud pattern is 5x114.3 centre bore is 66.1 Centre bore can be larger but a spacer ring is required but not smaller. offset i think 38 or 40 .I have few freinds who drift and they go on about gay offset wheels 35+ to 50+ because they tuck under arches to much . The wheels on the back of my z are 9" wide with a 35 offset and 20 mm hub centric bolt on spacer that makes them a +15 offset .Front are 8" wide with a 25 mm bolt on spacer that makes them a +10 offset.Some cars can run - Offset eg - 15 TO -70 but wheels but will need flares or pulled and rolled arches .I like the drift look with wheels flush with arches .plus a wider track is good.Lower the offset the more they stick out also clearing front caliper alot more for bigger calipers . im sure a 300zx will take a zero offset 8 " wheel on the front without hitting the front arch.
I hate the wheels tucked under the arch - I like them flush with the arch. My last set of RsRs fitted very well and I have just checked an old one and it was +35. The new ones arrived today and have a much deeper dish. Thanks for this info I have never worked out if +ive or -ive means they stick out more. I had a wheel delivered to work once and the secretary asked if it was to put on a tractor.
People always seem to say keep away from spacers if possible, so I was trying to get a set of wheels that bolted straight on. Brakedust300 - thanks for the link - only I can't remember what stock wheel width is. I'll check these new wheels with it later.
That would be excellent. AB is more or less round the corner from me. I'm going to try and get a word tomorrow after work, and then take it round to him after I get it back from painting.
