Hi guys,
since one of my rear subframe bushes has split, I am thinking of replacing only the 4 subframe bushes with polyurethane ones.
is it possible to just lower the subframe and change these four bushes or do I have to remove the subframe completely? secondly, what do you guys recommend I use to remove these bushes, some sort of puller maybe?
thanks
darren
I'd like to know too as I have a full poly kit that I want to replace my subframe bushes as I have a knackered one too.
Ive been told that brake lines and axle need removing? is this true?
You will have to drop the whole subframe and get it under a press bit of a mission
You thought about getting those sub-frame spacers? I believe they can take up the slack you get with old bushes - and only take about half hour to fit.
If the bushes arnt to shagged you can use whiteline subframe locking pineapples .Just fitted them to mine my bushes were ok just done it to tighten up the rear.half hour job.Ive removed all four bushes before on a s13 200sx same subframe and its a nightmare \hammer \blowtorch\ chisel \drill .
Yo m8 good to see you on sunday at the Lakeside meet, Were/who did you get the bushes from ? cos ive tried a few places in our area and know ones got any ? cheers m8.
By the way i like your car a lot, its got some nice goodies.
Hi mate bushes from demon tweeks not alot cant remeber how much i brought them for my s13 there the same fitment as s13/s14\r32/r33\r34\z32\ easy job just undo all four subframe nuts one at a time and fit between big domed washer and subframe.Hold subframe to body nice tight.Im also fitting 6 rear hub bushes 2 in the rear hubs both sides and 2 in both the short link arms .Not going to bother with rear upper arm bushes im going to replace with ajustable cusco ones .see you at the next meet mate might go to santapod . :dance:
