I'm just about to order a new broadband connection through Nildram and will need to buy new equipment. The current setup is 2 desktops and one laptop, each with their own dial-up modem. It is my intention to set up a wireless network and have the three share one broadband connection.
I've been looking at some Linksys gear which has been recommended to me by a friend. However, having never set up or worked with a wireless network I'm a little confused as to what gear I actually require and how it is all connected.
I'm looking at buying a 108Mbit "gateway", 108Mbit PCI card for each desktop and a 108Mbit PCMCIA card (these are all so called "speed booster" bits of kit based on 54Mb ADSL-g). I understand that there is a physical connection between the gateway and the adsl socket. The gateway also has four network connectors at the back. The question is, do I need to connect the two desktops physically to the gateway using these network connections or can they be connected "wirelessly" to the gateway? I would hope so otherwise there isn't much point to a "wireless network" ...
Also, apart from the above components are there any other accessories I should be looking at? I will also be getting a wireless print server in due course. Oh, and what is the difference between an ADSL gateway and router?
Hi guys,
Many thanks for your help!
Dan
