Auto to manual conversion N/A
What is needed for me to convert my Z from auto n/a to manual n/a...
Do I need a n/a flywheel or can I used a TT flywheel in this conversion?
Thanx man, good lookin out
Use a TT flywheel if using a TT gearbox, if using a n/a gear box can use either but if TT one is used you will have to space the starter out 2-3mm.
As for other parts needed:
ย
Clutch peedle/box
Clutch master cylinder, slave cylinder
Clutch fluid lines with brackets and heat shields
Alternater Harness
Shifter Holder bracket and dust boots
Manual center console
Drive shaft ( n/a vs TT are different )
Clutch kit
Spigot bearing
Engine backing plate
ย
You will also need to do some wirng to get the reverse lights to go.
ย
I think thats about it .... OH and take the engine out, makes life a lot easier
