Noticed that the boot that protects the suspension strut has perished on two corners of the car, anyone know if its much of a job and/or much money and time to sort. Is it something that should be sorted straight away or is it minor?
cheers in advance Dave
ย
ย
if its the rear then you need to remove the whole trim from the boot to reach the top struts undo x2 12mm bolts drop shocker strip down and replace cover
ย
front is alot less time consuming undo drop shock strip can be done in about 1hr for both
ย
rear is a couple of hours at the least
For the boot you can use a steering gaiter, available from any friendly motor factor, only cost a couple of quid.
Do they do those universal ones that just kind of glue together in the middle to save you taking the whole strut out? Just a thought.
