speedo flickering?
hi, just dropped the wife off in town, & give it a little burst on the way back. i didnt think it pulled as normal, but i was in third, so maybe the revs were to low & i should of cogged down, anyway an alfa pulled out straight in front of me & as i braked i noticed the speedo needle flickering. dont know if its anything to worry about or not, but if it is i would rather know!
its a jap tt, chipped, delimited & foam filter (crap i know)
thanks steve
cheers, i'll keep my eye on it.
Speedo was flickering on mine for about 8 months. I was advised it could be dry joints on the circuit board at the back of the speedo. I took the dashboard apart last week and removed the speedo. I resoldered all joints on the board and cleaned the membrane connections.
The dry joints can cause other systems to fault aswell. It can effect the cruise control and power steering. I did have the HICAS lamp come on aswell.
It doesn't take long to remove the parts. You will need a fine point soldering iron though.
Speedo now working fine.
