Greddy De-cat Pipes
Hi guys
I have brought a set of De-cat pipes off GetGreddy. To fit a UK TT '93 manual.
Can i fit them without removing the gearbox? I have managed to remove the heatsheilds off the passenger side pre-cat, JUST. It looks really tight to unbolt from turbo.
If you can remove. Do i need to remove O2 sensor first? Then unbolt from turbo, or can i remove as one lump?
Plus, the O2 sensors do you have to use the correct tool? I am also fitting a Profec B, which while removing loads of bits to get to has allowed me good visibility to O2 sensors.
Regards Kevin :duffer:
Hi bud , are you gutting the precat then ?? or are you wanting to just fit the decat pipes ??
