heated seats wiring
hi everyone
how are the heated seats wired up on the z ? is it just a case of +/- feed or is it relayed in some way..
cheers
gaz
Heated seats ?????????
did they all have this ? or am i gonna be simpled here, and find i have it too
I have fitted UK 95 spec heated leather in mine. I gave the seats a direct feed with nice size cable. These seats draw a fair bit of current so dont use speaker cable!
Both my seats are just good for power movement at the moment as I never did get round to connecting the heater contlol switch. I believe all the relays are built into the seat but not 100% sure. Maybe someone can clarify ;)
The contol button also needs to be wired up. I know on mine the wing mirror connector is different and you also loose use of the folding mirrors. I've got to jig something up there when I get more time ;)
Andy
so its really just a case of supplying power to the heater element?
i an going to buy two illuminated switches from the likes of maplins and wire them up as i cannot source the original heater buttons.
i would fit a relay - its not so much supplying a decent sized wire (tho you need that too!) but that the switch will eventually burn out switching that amount of current on & off
ive never fitted a relay before (cue dumb ass jokes) do i need to get a special holder or can i just solder straight onto the relay pins ? any chance of a diagram :rolleyes:
Deffo need a relay. But like I said they may already be built into the seat?;)
Need someone to clarify. I aint got my car at the moment so cant check for ya.
If not you can buy a relay and holder from any electrical wholesaler. (12v) Wiring up is fairly easy and a diagram should be given in th e packet.
Will draw you a diagram though if you get stuck.;)
Andy
Do you need heated seats in a Z?? Does'nt enough heat come from your a55 as you lose your back end around a corner or when you boot it?? LOL.
no i drive an na lol
but im a wimp in the winter and also if the seats have them, might aswell have them working eigh!
