Is this why I was using a bit of oil?
vbgarage.php?do=getimage&id=2038
What amazes me is how one of the rings has jumped up onto the gap above! :o
I can see your ring is well worn chris, is your bore damaged too?
:rofl: :rofl:
Not good Mr Carter!!
Ohhh Eerrrr!!!!!!
Don't let Jonce know you've been checking out Chris's ring.
He'll be wanting to know why it's well worn, as he's been over in Germany since JAE weekend.
I fear chris's ring might be broken due to excessive play,
The up and down movement has put serious friction on his ring and caused it to wear,
and the lubrication was obviously not applied in the right areas,
Any further use of his ring would most probably cause a seepage of fluids into his internals
:nono:
LMFAO!
Why do all my posts get turned into some kind of arse appreciation thread?
I think you lot should have your own botty bashers forum :rofl:
woh, thats quite something how its gone up above into the next gap like that. Would have thought it would just shatter or something. Is your bore ok, or have you bored it bigger ?
PMSL @ Mr. G String!!! :D
Christ all mighty Christopher, how many sets of forged pistons has the Liberace mobile been through now mate? :(
zero
lets see if you can keep it on the road now chris for JAE 2006 :D
