Boost Drop
OK for some wierd reason my boost drops from 6.5 to 5 when the car warms up.
Every time i try the on board consult it reads 55 i've tried testing it when it looses boost leave the car on then try the test but nothing happens unless i turn the car off then onto just ignition by this times it's re-set itself....
Can anyone tell me why it only looses boost after it gets hot and how i test the ECU on board for code 34 without a laptop???
It can't be the det sensor as Ryan changed it some few months ago i've also check the wiring from the loom to the plug and this is now all fine???
Could it be the wiring back to the ECU or something else?
The temp sensor is also new by the way??????????????????
Alex
No posts to show
