With standard tyres -245/45ZR16 on 8.5J X 16 rims, the manual twin turbo (final drive ratio 3.69:1) the turbo achieves the following speeds:
Gear MPH RPM
1st 43 7200
2nd 72 7200
3rd 107 7200
4th 139 7200
5th 155 6000 with speed limiter
5th 165 6400 without speed limiter
5th 186 7200 intermittent theoretical, rev limited
ย
The equivalent table for the non turbo, final drive ratio 4.083:1 is:
Gear MPH RPM
1st 39 7200
2nd 65 7200
3rd 97 7200
4th 126 7200
5th 148 6300 Power limited
5th 168 7200 intermittent theoretical, rev limited
ย
The automatic ratios are: 1st 2.78, 2nd 1.54, 3rd 1.00, 4th 0.69, so results for the turbo are
(Maximum, as actual speeds will depend on torque converter slip):
Gear MPH RPM
1st 48 7200 Held in first
2nd 87 7200 Held in second
3rd 139 7200 Held in 3rd, overdrive off
4th 155 5500 with speed limiter
4th 178 6400 without speed limiter, not attainable by stock TT
4th 201 7200 intermittent theoretical, rev limited
ย
The equivalent table for the non turbo automatic.
Gear MPH RPM
1st 43 7200 Held in first
2nd 80 7200 Held in second
3rd 126 7200 Held in 3rd, overdrive off
4th ?? ?? maximum??
4th 161 6400 not attainable by stock NA
4th 182 7200 intermittent theoretical, rev limited
MMMMMM my speedo is out then as I'm registering 120 in 3rd and 150 in 4th then I ran out off track.
ย
All on safety boost. mmmmm Will know for sure when I put my snooper with GPS back in.
The stock speedo goes really out after 80mph.
I was going over 100mph according to the speedo but the GPS system I have was saying 90ish.
ย
Upto around 70-75mph they where virtually identical
As on a previous thread, when comparing GPS speed with speedo make sure your on a level road or it will be out on the GPS. I know because I have tried it and there are definite discrepancy's between level and flat roads using GPS speed.
