I got a 300 tt from '93 (originaly sold in Germany if that matters). Two weekends ago, we did some minor repairs on it. One of the things we wanted to do was to correct a problem with one of the front lights. This involved getting in to the front light unit and unless we did a lot more work than needed (it was the first time, so how knows), getting that unit out means taking of the front and some stuff behind it.
This seemed to work well, but when I took it out for a spinn, the engine died on me by a red light. No obvious cause so I had to get towed back home again. It seems only logical to start with the areas we touched when we did our repairs and the only engine related thing we touched was the air flow meter. Fiddeling a little with the connector seemed to magically solve the problem. Testing this a day later, the car started without a hitch. I left the engine running for 5-6 minutes, no problems. Tried to drive away, 50 meters later, the engine caughs twice and I have to be towed for the second time in three days. :(
The engine managed to run ones more for a short while, and now it won't start.
First we tried to run the self diagnostics of the ECU. Mode I reports that it is working correctly. Mode II - an utter failure. The diagnostic mode selector isn't there! There's no trace of it. Could it be placed somewhere else (not on the ECU) in my car, or did they make versions without it?
We've checked the different parts of the engine. There's gasoline in the clyinder and there's a spark on the spark plug but it doesn't ignite. The only thing that I can se missing would be air. Wich brings us back to the air flow meter. As I understand it, there's a fail safe system if the air flow meter should fail. If it fails, the car will still run but at a maximum of 2400 rev/minute so it doesn't sound like that's it.
I'm out of ideas. Any help will be apreceated.
