Guys, ive got a 2.5" system straight thru and have also had the CATs knocked out.
Now i had to have a bung put in each tailpipe to cut out the excessive drone i was getting between 2k-3k RPM.
It did the trick but makes it sound a bit sh@t on idle cos u get a weird blowing noise. Now i was thinking about having proper de-cat pipes fitted with Resonators and hopefully then i could remove the bungs from the tailpipes.
Has anyone else had this problem and do you know if this would work, suggestions??
Cheers,
Dan.
