Some ideas of what to do with electro luminescent board
Have a look at this:
The pieces are made from bits of EL board with the markings stuck on the front. You should be able to to the same with the larger dials.
They have also cut holes in the plastic side kick plates and stuck some EL board behind those:
The power is taken from the interior lights.
Anyone know where and how much you can pick this stuff up for?
Trev
hmmm i like the neon fairlady thingy that looks cool.
i have seen these around somewhere.
Trey on another note whats happening with your car?
the clocks we are still in the process of getting i believe.
Are our clocks backlight?
the best has to be the rear panel illumination
where can you get that stuff from its cool stuff
Heres how the stuff comes in the japanese kits:
Heres how it looks once power is applied:
This is how one guy did the rear light finisher using EL board(This stuff looks cool biggrin.gif ) http://zetton.power.ne.jp/lady/photo/finisher_light/index.html (My Zed came with the lighted rear panel but I think it uses bulbs).
Trev
Had the kick plates on my FTO, the E.L panels are about £20 and the inverter PSU is about another £20, you can get these all from RS Components as I had to repair my old ones.
The rear 300ZX logo should be a piece of piss to do, you don't even need a relay as the current drain from the inverter is so small.
I'll have a look at prices when I get back to work on Wed
Well done that man!
Electro luminescent sheet, 60x50mm, blue green = £4.62 or £18.19 for 130x120mm at RS Electronic
http://www1.rswww.com/
Trev
Translate Trey's link http://zetton.power.ne.jp/lady/photo/finisher_light/index.html
with Babelfish - well funny, you get great descriptions like this.
'Job well enough was serious, but when you try ending, spending time, the joy above the value which challenges gushhes forth. '
lol yeah, can u get the stuff in other colours like blue or red? Blue would be super cool
Take your pick:
Not sure how they look when they are lit up though, I may look into buying one of each of the small bits(£4.62 each) and test it out. The dark blue with white markings would look good.
Trev
