hi could anyone tell me if you do a manual conversion do you need to change the ecu?
You should not need too! Just remove the Autobox ecu not (Engine Ecu).
You can fit a manual ecu if you want though.
Your car would still have auto turbos, so may as well stick with auto ecu.
Are they different? I didn't know that. Any luck with your brakes by the way? Dave
