Horrible vibration at just bellow 2000rpm
As the tittle says. Smooth as anything bellow and above. Any one know why its doing it.
Could be prop shaft bearings.
got a similar problem from idle to 2000rpm getting a louc clicking noise but unsure where it is coming from have jacked the backed and found nothing now scratching my head plz help
Wouldn't be those if it only does it at around 2,000rpm, but goes away the fast you went.
The faster you went, the worse it would get, so 2000rpm in 1st and 2000rpm would be significantly different.
my problem only occurs when the engine is not under load as soon as you give some throttle the noise stops and is increased at low speed under breaking got me totaly confused
Mine to!
Well I found out what was tha cause of the bad vibration. It would appear that it was cause by the paddle clutch I had dragging and never properley releasing. (So a certain person I've given a lot of sh1t to about this will proberbley be please in one sense)
It's been born out with the fitment of a Exedy Carbon Alloy twin plate which I have to say is as smooth as butter, but at the price, it should be.
