In memory of Mandy
Friggin boost leak
wel since ive had my car ive suspected a boost leak, but can i find one? tried everything.
Bought a boost leak detector but cant get anymore than 0.10 bar or pressure in the system, using and electric pump.
whilst driving ive manged to get .9 bar boost as max but today im getting only 0.7 (std) with a boost controller.
hmm bit difficult to trace baisically check all your hoses if you suspect a boost leak, you will also hear a noise like a screaming kettle if you are loosing boost!! when you drive the car foot down!!
do an ecu diagnostic see if you are in safety boost :cool:
wont get saftey boost as have boost controller installed. deffo a boost leak you can hear it when i boot it, but finding the blumin thing is something else.
I see in your signature you're replaced you vacumn hoses, what clips did you used. If they're those with tightnen bolts on them they might have cut into the hoses. Best to use clamping clips. That's what I need to do now with mine.
